Moving the phasing with an adjustable rotor would be easiest. For distributors that don't have adjustable rotors available I think you could still index the rotor at the vacuum advance, which won't be used any more anyway. Instead of moving the rotor tip you would lengthen (I think) the arm on the vac advance. Or fab up a lock out plate.That would be a sensible feature, given all the possibilities for it to be incorrect, but what do I know....
