Moparvinson
I cleaned up the big ball joint upper control arms I got from a 74 dart sport. I can look through the bolt holes on the drivers side bushings and they line up straight. When I look through the holes on the passenger side one is definitely off from the other but they were bolted to the car when I got them and the adjusting bolts and adjusting washers were all in and straight. I am assuming they should be straight. Can this one be fixed? Thanks.
