Bergman Auto Craft October Promotion
BergmanAutoCraft
FABO Vendor
FABO Vendor
Hampstead, NC
Bergman Auto Craft beats the competition again by offering the original SPC Gen 1 upper control arms for a budget friendly 499/pr! Testing revealed the need for a more stable mounting solution. We use a greasable delrin bushing assembly designed to fit the Mopar mounting sockets just like a stock arm.
Bergman Auto Craft/SPC Upper Control Arms allow the highest degree of adjustment on the market. These arms allow a wide range of adjustment without touching the factory eccentrics. This arm features delrin bushings with grease fittings for precise and quiet operation. Wheel alignments are greatly simplified due to the double adjustable design. Arms are sold by the pair with large style ball joints, hand assembled and ready to install. We are the exclusive supplier for this arm with high performance Delrin bushings installed.
Enjoy 10% off during the month of October using discount code BAC10
BAC SPC Upper Control Arms - Bergman Auto Craft
VERIFIED FITMENTS:
67-72 A Body, with late disc spindles
73-76 A Body
70-74 E Body
Is aesthetics the only difference between Gen I and II? I have previously purchased the Gen I set from you but was eyeing the Gen II’s for my next purchase.
The gen 2s are fully forged construction, the only arm like it on the market. It features a taller ball joint for improved geometry. For mounting, it has a thin, high durometer rubber bushing. Otherwise, alignment adjustments are done the same way as the gen 1.
