swinger340
Going to be running a comp XE282S solid flat tappit cam in a 340 im building. What is the best oil to run in order to avoid premature lobe wear?
Schaeffer oil. Available online or at local dealers.
The 7000 oil has 1600 to 2000 ppm of zinc:
Schaeffer 7000 tech data sheet
Been using it for decades. The website has a retailer locator as well as an online store - or just call them up.
B.
if u stay with brad penn, joe gibbs oil, youll be fine.....
x2 I've been using Schaeffer's supreme 7000 for about 15yrs.
20w/50 if you heat your oi pan before starting
