That's the easiest.
Put it on a tire, up against the front of the bed and strap it in.
Tire works pretty well. Strap it down from the four corners, keeps it from pitching.
I don't know of simpler an better. There are probably better, but the used tire is about as simple as it gets. I have hauled several engines on an old tire and it has always worked well. I hauled one on a wooden stand that crate motors come on and kept having to tighten it down because of vibration. The screws holding it together started pulling out so I stopped in the middle of South Dakota and begged a service station for a junk tire, tipped the engine over onto the tire and tied it down. The engine stayed tight and in place the rest of the trip.
Thats as simple as its going to get. I've done the strap/tire thing more times then I can count.
Or take a tire and throw it in the back of your truck ,strap it down, stays put,get home , remove engine ,throw tire away, done deal.
I have always used a tire.
I hauled a 360 mag last year from erie pa to central wv.
Just put 4 straps on it a go.
A 15 inch truck tire like a 235/75/15 works real good.
Tire, lot of times we don't even strap them down, just remember to take it easy around corners.
Here's a radically different idea:
Use a tire!![]()
Just hauled one last weekend with a tire and 4 tiedowns, about 120 trip, worked awesome!
all these guys are crazy!!!!! just use a Tire!:thumleft:
thats how they leave my buds machine shop. On a tire.
I believe it's a law you have to use a tire.
dunno if it's a law, but I'm pretty sure I saw it recommended somewhere.
I can't beleave no ones suggested a tire by now. :dontknow:
Gotta be a 15
I go with these guys !!But whitewall or raised letters up for more traction !!!
