[SOLD] big bolt Disc spindles, 11 3/4 caliper brackets, big ball joint upper control arms.
ssba
rensselaer in
These new spindles are correct for the 73 up big bolt disc conversion.
These slider type caliper brackets use the 11 3/4" cordoba rotors which require a minimum 15" dia. wheel.
The upper control arms are the correct used take offs to work with these spindles on a 67 up car.
350. for everything shown or split them up?
I also have the rotors, calipers, bearings and new Moog parts in the boxes if you needed a complete swap kit.
11.750 caliper brackets and big ball joint upper control arms still available.
200.00 + shipping for both pairs of parts or 100.00 + shipping for choice of either pair.
