[SOLD] Big bolt pattern aftermarket axles - Mopar 8.75"
70Duster440
Washington
Shipping from: Wenatchee, WA 98801
Price: $200 + Shipping (43 lb. Pkg - not cheap)
Payment: Vemo or PayPal + fees
Mopar 5 x 4.5" bolt pattern custom cut axles from Doctor Diff. 30 spline with Green bearings. Were in a slightly narrowed B-Body housing so they're longer than stock A-Body but shorter than B-Body. They measure 28.5". Stock A-body used 28.0875" so if you trim 1/2" off the splines you'll have the correct width. Lots of spline available for other narrowed widths. See his calculator for options: http://www.doctordiff.com/axle-calculator/
Less than 1700 miles. Changed housing so these are no longer needed.
28.0875" is less than 28.5" unless you added a zero in there thats not supposed to be there even then if you remove the zero, it would only be slightly more than 1/4" that would need to get whacked off the spline end. Just trying to help potential buyers. You may have made a typo.
Back side of green bearing to edge of splined end appears to be 24&5/8" these are stock width A body dr diff.
Thanks for all the measurements. Now back to our regularly scheduled program.
