yellow rose
Overnight Sensation
Did you get drunk and put both bearings on the rod side? Sorry, that's the only possible explanation I can produce on such short notice.
I've seen that happen without being drunk.
The Swami and his crystal ball strikes again!It's possible. Haven't seen that but once since 1974. Also possible is that the rod nuts have backed off. He will simply not know without verification.
Yes. I think I said it somewhere in here already, but when I pulled the pan the nuts where half off of the rod and it was not sitting on the crank all the way.Did you ever figure out what caused that 1 piston to stick up too high? Wrong C Height on that piston?
