Billet brake drum?
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I'm not a machinist or metallurgist but was wondering ... other than cost couldn't a brake drum be machined from billet steel / iron?
Thoughts?
Pros?
Cons?
for drums that are no longer produced. Not a mopar specific question but might apply some day.
The cost could be $750 to $1000 per drum. Anything is possible with enough money.
there are a few specialty that are making aluminum drums but none for mopar that I know of.
It seems like it should not be too involed.
or maybe just reline exhisting drums?
My question has taken sn aluminum turn.
Im asking about steel /iron billet and nothing csst
In that case, other than the cost, you could have billet drums made. My concern would be the metallurgy involved. Would a billet drum hold up to the heat generated?
AND I'm imagining the massive chunk of metal it would take to make one. Should it be heat treated? I don't know.
If you need small bolt pattern drums you could redrill the 4.5 pattern drums.
There is said to be difference in the depth between SBP and LBP drums.
I ordered axles with both patterns and plan on drilling the drums for both as well.
I might have to turn them on the lathe to remove a little
Different width on the shoes? You can make lots of parts worth with a little imagination and a good machine shop.
