Bleeding new brake system
green72
cedar rapids Iowa
72 Scamp power disc front, drum rears 225/6. All new system I am try to bleed but cant get fluid past the distribution block. What am I doing wrong?
Did you try both front and rear? If the slide in valve moved it would block one direction. Is the valve new?
If you have too mush flow to one direction, it slides and closes it off. The idea is if a line broke you would still have some brakes. If you pushed pedal hard with rear open and front closed it will probably need to be physically reset to center. I've rebuilt one, but never had to reset one in the car. Anyone?
Can anyone tell me how to reset the valve to the center? I can get fluid to the fronts but fluid will not pass distribution block for the rears.
