1. anthony cox
    anthony cox Member
    8
    9
    Mar 8, 2020
    dectur al
    Local Time:
    8:38 PM
    1965 Doge Dart has blow by from the oil filler cap and the PCV cap. I believe it's leaking oil from the oil filler cap. It's runs very good, I drove the car 30 miles at 70mph without any issues. Any suggestions on what this might be?
    It was setting up for a few years before the oil was changed and the fuel system components replaced.
    Thank you,
    Anthony
  2. Hyper_pak
    Hyper_pak Old School Chrysler Fan
    2,413
    1293
    Feb 14, 2010
    Desoto Texas
    Local Time:
    8:38 PM
    Do you mean after this oil change it started, or is this bringing it back after many years off the road? Sometimes a thin oil on an older motor will cause you some problems. It might be some rust on the cylinder walls and it might work in some.
  3. missing linc
    missing linc Loose nut behind the wheel FABO Gold Member
    1,063
    1428
    Feb 17, 2019
    Southern Alberta Canada
    Local Time:
    7:38 PM
    Rings will probably need to re-seat, stuck from sitting for an extended period.
    • Agree Agree x 1
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      2,346
      1825
      Jan 1, 2018
      Southwest VA
      Local Time:
      9:38 PM
      What engine is it? It’s time for a compression test.
      • Agree Agree x 1
      • Slantsix64
        Slantsix64 Well-Known Member
        2,205
        818
        May 11, 2014
        SGV
        Local Time:
        8:38 PM
        20w50
      • Charrlie_S
        Charrlie_S Well-Known Member
        2,777
        663
        Oct 17, 2005
        Silver Springs, FL
        Local Time:
        9:38 PM
        Check the PCV system. It is common for the PCV passage in the carb to get plugged up. If it is, just remove the carb, and clean the passage, through the tube, and up from the base (makes a 90* turn) with a 1/4 inch drill bit, by hand.
      • valiantwagonguy
        valiantwagonguy Well-Known Member
        864
        571
        Oct 20, 2005
        Long Island
        Local Time:
        9:38 PM
        Well, my 65 Valiant wagon had bad blow by,it got so bad I had to keep the windows open and hook a vent hose from the oil fill cap to the air cleaner just to drive.The day before I pulled the motor to put in a known good one I had it on the interstate going 70 mph. She ran like a top. After I pulled it I tore it down to see what was causing it. Results : #1 cylinder has the top edge of the piston melted away and 2 broken rings , on 4 of the other cylinders I found broken rings as well. The thing just wore out ! She had 350,000 miles on her and still ran like a top with all this going on inside. This is how strong these things are ! You'll probably find similar stuff inside your motor if it has high miles as I suspect it does.
        • Like Like x 2
        • Agree Agree x 1
        • AJ/FormS
          AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
          17,564
          5956
          Jan 19, 2014
          South-Central Manitoba,Canada, 900ftelevation
          Local Time:
          8:38 PM
          You shouldda seen my slanty idling with a hole in the side of the block and the broken rod doing the crazy dance.
          that was not blow-by, but rather; blow out.
          Edit:
          were they tough?
          Apparently not tough enough.
          I've never windowed a SBM
          A friend of mine at a bush-party, once bricked a 318 gaspedal at WOT . After 20 minutes of listening to that thing roar, somebody flipped the brick off. It stalled and would not restart. I bought the car for $50, and pulled the heads off. Hyup there was the evidence; the valves had hit the pistons and were bent.
          A couple of hours later, with different heads, and she was back in action.
          • Like Like x 4
          • 340doc
            340doc Well-Known Member
            2,476
            827
            May 8, 2010
            Hollywood Fl
            Local Time:
            9:38 PM
            My old slant in my 71 had such bad blow by, I couldn't keep the hose from the breather connected to the air cleaner. It would push so much oil into the air filter it would clog up. I finally ran a long hose from the breather down to a container by the frame rail. After a long drive on the highway I'd pour the oil from the container back into the engine and keep going!
            • Like Like x 6
            • AJ/FormS
              17,564
              5956
              Jan 19, 2014
              Local Time:
              8:38 PM
              I was not as smart as you,lol. I ran the hose down below the oil pan and oiled the road. 4 quarts of oil to a tank of gas.
              • Like Like x 2
              • 340doc
                2,476
                827
                May 8, 2010
                Hollywood Fl
                Local Time:
                9:38 PM
                Wow, that's a lot! Lol
              • MOPAROFFICIAL
                MOPAROFFICIAL Well-Known Member
                5,030
                4008
                Jun 1, 2016
                Beach
                Local Time:
                6:38 PM
                Rust on the cyl walls, that's an oil burning cause...the rust doesnt just wipe smooth...and if it rusted at the ring..there is now a groove the circumference of the cyl where it rested those years. The surface can leave small pits for blow by
                Could have already had many miles on it to boot.
                Burning oil under load/throttle. Rings
                Burning oil only at start up, seal and guides.
                • Agree Agree x 1
                • AJ/FormS
                  17,564
                  5956
                  Jan 19, 2014
                  Local Time:
                  8:38 PM
                  It looked like a cartoon car for a couple of months. 65 Valiant wagon. Then I put a 340 into it and had a different smoking problem,lol.
                  • Like Like x 1
                  • pishta
                    pishta I know I'm right....
                    16,511
                    6198
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    6:38 PM
                    PCV on a 65 Dodge was just a mild vacuum source for the crankcase to promote a constant ventilation of oil vapor into the carb base to prevent sudge and moisture condensation. The oil filler was a slip fit cap with a brillow pad filter in it. I dont think a plugged or lack of PCV on a 65 would cause blowby control issues as its already vented to atmosphere through this large opening. Also the umbrella valve seals are probably long gone and are already in the oil pan as black plastic gravel.
                    • Like Like x 1
                    • AJ/FormS
                      17,564
                      5956
                      Jan 19, 2014
                      Local Time:
                      8:38 PM
                      Hyup, and the shovel on the pick-up is jammed full of it.
                      Seen lots of those
                      • Like Like x 1
                      • Agree Agree x 1
                      • anthony cox
                        anthony cox Member
                        8
                        9
                        Mar 8, 2020
                        dectur al
                        Local Time:
                        8:38 PM
                        3.7, it doesn't seem to smoke out the tail pipe
                      • valiantwagonguy
                        864
                        571
                        Oct 20, 2005
                        Long Island
                        Local Time:
                        9:38 PM
                        It's not smoking out the exhaust because all that crankcase smoke that blow by is is making it's way past your rings and past your valve guides into the top of the head and also down into the crank case and coming up as the crankcase gets filled with the gas that's passing the rings and worn out pistons & cylinder walls . The motor is tired and worn out. This is how they die
                      • 66 Valiant wagon
                        66 Valiant wagon Well-Known Member
                        80
                        79
                        Jun 16, 2019
                        Minneapolis, MN
                        Local Time:
                        8:38 PM
                        My slant has had blow by the entire time I've had it. (3 years) I've put on about 15,000 miles in that time.
                        Your muffler is probably full of carbon which is why you're not seeing it too bad from there.
                        Mine also runs like a champ at 70 mph. I've tried everything under the sun, re seating the rings, adjusting everything again and again. I think the rings are just bad and I am gonna pull it later this summer and rebuild it.
                      • MCPObr44
                        MCPObr44 Well-Known Member
                        70
                        28
                        Jun 22, 2018
                        Rodeo NM
                        Local Time:
                        6:38 PM
                        Holy wow, and here I was worrying about the blow by in my 225... and it's nothing like what you guys are describing. Just some oil in the air cleaner after thousands of miles.
                        On another note, have you guys heard of the cap dance test? It's something diesel guys do to check for blow by. You loosen your oil filler cap and let it just sit there on the valve cover with the engine running. If the cap stays still, you don't have much blow by. If it dances around and or completely flies off the cover, you've got a lot of blow by.
                        Does this apply to gas cars too? My cap doesn't move at all, but I feel I still have blow by.
