jarvitron
OK, so Princess decided to blow a head gasket. Didn't seem to be overheating, and I don't feel like doing a big ol' proper rebuild on a 70's 318 (since I found a 5.9 magnum not too far away that I'd much rather tear into), but while I prep that engine, I am planning on doing a carport head gasket and timing chain job. I have a shop close that I can take the heads to to check the mating surfaces, bought a cheapie Felpro gasket kit and a timing chain just to get her back on the road and take the gamble on the bearings and lifters surviving the drive.
My question is this: It did put water in the oil, and it was started/driven a couple blocks, meaning there's contaminated vinaigrette all through the motor. Obviously when I do the head gaskets I'm gonna do an oil change, but what precautions should I take before I start it up? Put a couple quarts in the pan and prime it with my drill to flush the gunk out, then drain it and do another oil/filter change? I know I'm cheaping out but I wanna maximize my chances here (for at least another 1500-2000 miles/2 months, while I prep the magnum to swap).
Thoughts? Emotions?
Thoughts? Emotions?
