thank you@Johnny Mac Maybe Johnny can assist, he works at Blueprint and is a member here..
ok
Assuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler CompatibleHey guys, got a hold of a 2015 Blueprint 408 and need to find out if l need an externally balanced flexplate. Any info would be great, thanks.
thank you J MACAssuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler Compatible
anything wrong with using a knockoff?thank you J MAC
anything wrong with using a knockoff?Assuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler Compatible
I'm unsure anybody makes one. But I don't think anything would be wrong with it as long as it was the same style. You should verify 100% that's what you need though.anything wrong with using a knockoff?
Do not forget the externally balanced Harmonic Balancer and if not you will have one heck of a vibration.Assuming your converter is neutral balanced, as most aftermarket are, you need this flexplate. Chrysler SB Steel SFI Flex Plate - LA 360 SB EXTERNAL BALANCE 727 and 904 - Chrysler Compatible
got itDo not forget the externally balanced Harmonic Balancer and if not you will have one heck of a vibration.
DODGE Summit Racing SUM-G124SFI Summit Racing™ SFI-Approved Flexplates | Summit RacingI'm unsure anybody makes one. But I don't think anything would be wrong with it as long as it was the same style. You should verify 100% that's what you need though.
looks darn closeI'm unsure anybody makes one. But I don't think anything would be wrong with it as long as it was the same style. You should verify 100% that's what you need though.
Using a flexplate made by "lord knows who" would be a really poor $90 to try and save in my opinion, when the manufacturer that makes the engine, sells one balanced and checked, again to the correct spec. On a new engine install, if you find a vibration, I would sure like to know I'm not pursuing a "store brand" to help diagnose. Not dogging any reseller or WD, but just my opinion.anything wrong with using a knockoff?
Harmonic Balancer - Chrysler Compatible - 273, 318, 340, 360 and 408Do not forget the externally balanced Harmonic Balancer and if not you will have one heck of a vibration.
Thats a pretty old engine. Who knows what it's been through. May have been internally balanced by now. What does the damper look like?Hey guys, got a hold of a 2015 Blueprint 408 and need to find out if l need an externally balanced flexplate. Any info would be great, thanks.
haven't pulled it yetThats a pretty old engine. Who knows what it's been through. May have been internally balanced by now. What does the damper look like?
Yeah, that'll do it, if that's what it needs.
EXACTLY why I am recommending he verify what he has.Thats a pretty old engine. Who knows what it's been through. May have been internally balanced by now. What does the damper look like?
