Bluetooth amp on order, questioning how to wire 3 speakers?
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
I'm looking to wire up 2 rear 6x9's and one front speaker. Only thing I'm finding is to wire the center speaker using both positives (not sure how that would work). Thanks.
https://www.amazon.com/Bluetooth-Subwoofer-Amplifier-Speakers-Password/dp/B08L4D2Z79/?tag=fabo03-20
So no front and rear separation? No way to control the volume front vs rear?
Correct, doesn't have to be perfect, just don't want to wreck anything. Going from a single bluetooth speaker on the dash it should be way better.
I did this three times, but with different equipment. In two cars, I made a mounting plate to hold a pair of 3" or 3.5" speakers in the dash location with a pair of 6x9's in the rear. In the truck I used a dual voice coil 4x10 in the dash with some smaller oddball speakers (like 5x7 or something?) in the rear pillars. All three are driven by a 4-channel head unit, about 20W per channel. I'm a hardcore audio guy and it makes plenty of volume - especially when I added a nice powered sub.
I don't know that using that 2-channel amp will work well with impedences on a three-speaker system.
S&M Electro in Blaine, Minnesota has a front two speaker that will bolt right into position where your single front speaker is.
