I haven’t found a better carb cleaner than hydrochloric acid. This is one that is at least 70 yrs old. The only thing it doesn’t strip well is any petroleum residue which I use industrial strength carb cleaner for. It’s great for everything else and outstanding on aluminum electrolysis, you know the white crusty stuff that is the corrosion
When water gets in an aluminum carb.
Cheapest way to get the acid is extra strength sno bowl which is a toilet cleaner. It is diluted. DO NOT add water
It can result in a chemical reaction and blow up in your face. It didn’t look too bad but had massive electrolysis inside
