SS Lancer
Which companies offer complete kit for drum to disk conversion for my 66 Valiant ?
Thank you
Thank you
Is that a complete kit ?I just used a Scarebird kit on a 64 barracuda
Really easy using stock upper control arms and lower ball joints
Very easy
Ok thank youI had to source a M/C and make a couple of lines
Otherwise it was complete.
I went to BBP, they also make a SBP kit
Nice kit good price also , I guess I have 9" drums on car its stock 66 Valiant
These are my Scarebird brakes. 65 Barracuda. I didn't use my stock upper control arm, went with a tubular control arm, but the stock one would of worked with no problem. Stock knuckle, small bolt pattern wheel.
Norm
Nice , if rules in club allow those upper control arms I will get those also thank you .These are my Scarebird brakes. 65 Barracuda. I didn't use my stock upper control arm, went with a tubular control arm, but the stock one would of worked with no problem. Stock knuckle, small bolt pattern wheel.
Norm
I used a scarebird kit on my A100 a while back. Cheap and easy.
If I remember correctly they supply the brackets and a parts list of over the counter parts to use.
You will have to modify your supply system. If you have the stock single reservoir master cylinder...it doesn't have enough volume to operate the disc system. You will also need to have a proportioning valve. This is what I have done to mine. There will probably be other suggestions for the installation, but this is how I did mine.
Norm
You can also use the factory setup for that year, or any '66-72 A-body if you want to keep the same small bolt pattern. Lots of other options if you want to change to the big bolt pattern.
I need large pattern front wheels already purchased
Aluminum? really? Yikes, not something I'd want to rely on when cornering and braking hard.the kit that I linked comes with BBP hubs aluminum
Those aren't for sale I don't believe.Nice , if rules in club allow those upper control arms I will get those also thank you .
