Bolt pattern 1965 Barracuda
Not likely to install G70x14 with an adapter due to backspace issues. To use a adapter between 2 cars the tires will have to fit both cars, even if poorly.
There is only one car here. If you use a one inch thick adapter you simply buy a wheel with a one inch deeper back space then the wheel would be if there was no adapter being used.
I do not want to compromise the original wheels and hub caps as they are correct for the car...... There again, I want to use the Hurst wheels every now and then ... As I think they would look great on the car.
Oops! My plan won't work, looking at it on a phone I didn't see the Formula style hub caps with the ecposed lug nuts.
