Oklacarcollecto
Life is an experiment
Not likely to install G70x14 with an adapter due to backspace issues. To use a adapter between 2 cars the tires will have to fit both cars, even if poorly.
There is only one car here. If you use a one inch thick adapter you simply buy a wheel with a one inch deeper back space then the wheel would be if there was no adapter being used.
