What is correct bolt size and tread type for rocker arm shaft bolts? I overtorqued them and now I need to replace them all. They stretched so badly I dont even know what tread type they are. I tried google but found no info.
Right.Yes, UNC is coarse thread; UNF is fine thread. And remember that some FSM's have the wrong torque for these bolts; should be around 15-20 ft-lbs, not 30 as listed in some FSM's.
Not meaning to be a downer here, just covering bases, check the threads in the heads and make sure you didn't strip/pull them out.........having stretched the hold down bolts, you may have damaged the heads.
Just be careful chasing threads on the rocker mount holes where the oil comes up; you don't need metal bits in your rocker shafts.
Put some axle grease on the tap before tapping and it will help catch the chips. Then spray out the hole with a spray can with a straw and then blow it out with compressed air...
