Because I can make way more power than that thing
i bought the same set of heads and rockers you did on black friday. I sold them before i tried them...I have a set of the offset aluminum sm rockers for victor/Victor copy heads. I bought them cheap on a black friday sale. I have NOT done anything with them yet.
I'm gonna use the Victor's on a 522, but I'm planning on a fairly conservative cam, so gonna try the sm rockers. If run into any problems, I'll have to bite the bullet and get the $1200 rockers. If I need to do that, I might as well put a big cam in too.
Today we went 4.60 at 161 at 3300ish pounds on a 8.5 radial. I’ll let you do the math on that one.
Nice LS !!Today we went 4.60 at 161 at 3300ish pounds on a 8.5 radial. I’ll let you do the math on that one.
Try againNice LS !!![]()
The Wallace calculator says 2140HP.Today we went 4.60 at 161 at 3300ish pounds on a 8.5 radial. I’ll let you do the math on that one.
38. We had to stack 150 pounds of lead on the car.
Try again. lol you’ve probably seen this car run a bunch at Irwindale.Looks like a bbc to me.
(Could be a bbf too, I suppose).
In seriousness, I thought it looked like coyote 5.0Try again. lol you’ve probably seen this car run a bunch at Irwindale.
It’s not a coyote. It’s a traditional 9.5 deck small block ford. With a killer set of heads on top.In seriousness, I thought it looked like coyote 5.0
CID SC2 or BES ?With a killer set of heads on top.
glidden victor sc1CID SC2 or BES ?
Deck the block and mill the heads and use some thin head gaskets. BlueprintedShe'll be "as-is" for the first go-around. We'll develop a plan while she's in there, however, I don't want to miss Speedmaster's 40% off sale (if they do it) if they have something that is good for the build.
Put a cam in it and send it.
Where did you run it today? Barona?Today we went 4.60 at 161 at 3300ish pounds on a 8.5 radial. I’ll let you do the math on that one.
We’re in Vegas for SCSN.Where did you run it today? Barona?
getting some gaskets in the cart..... I'm excited to see what the 7.5 compression 440 runs... (or at least that's what they are say'n) .... 250 hp and a 16.9 1320 coming my way.... they say...Deck the block and mill the heads and use some thin head gaskets. BlueprintedPut a cam in it and send it.
LOL....Gaskets? I thought the engine was already in the truck.
Are you taking the heads back off it now?Got some gaskets coming this way (Summit/Jegs) ... along with a couple other things... I probably already have the gaskets, but just mak'n sure LOL
He just LOLed me about it. So who the effff knows?Are you taking the heads back off it now?
no, just got to go back to the truck oil pan. Going to send it as is for now... I want to see firsthand how big of a pig this heavy, insufficient hunk of history is.... especially with one rusty cylinder wall . lolAre you taking the heads back off it now?
