Brainstormin' 440 vs 5.9 ...
In my opinion it’s worth less than that.
:lol:
But all of my experience is with small blocks. I have not used a big block version.
years ago... in the 80's, we had a single plane (maybe even a torker or tarantula style) on my brothers GTX. M-50's on the back, we could have 4 guys in the car at 50 mph and kick the rear tires loose. I still have the factory cast intake for the RV
LOL.... We'll build the 440 eventually. I'm putting it in as is now because I'm more interested in this project on what it's going to do than I would be in any car project in my yard or on youtube... But rest assured, 318willrun gives parts away, hardly anything comes my way for free. ha!
I like how you're doing it. It'll show just how much low compression and a stock cam affects performance.
In which.... it's really not comparing anymore (though they will). It's really just seeing what the biggest smog era RV Big Block will do... The magnum is far more efficient than what this 440 is as it sits
Do all the things to the 440 that the Magnum has. The 9 plus compression, hydraulic roller cam and 1.6 rockers. Then what happens?
TRYING..... to keep this on every page….. wow this copy and paste happens fast... :D
TT5.9mag --------- 16.90
jrc4y4 ------------- 15.30
dirty white boy—— 15.15
71GSSDemon ----- 15.00
Sharpone ---------- 14.85
Killer6——————- 14.81
69conv—————— 14.80
496 polara --------- 14.78
Turbo440Dart ----- 14.70
70SwingerGuy——- 14.65
Mopar44134———- 14.605
Curious Duster ---- 14.50
red67gts ----------- 14.40
a-bodyguy --------- 14.319
67/6barracuda ---- 14.20
junkyardhero ------ 14.00
440 Mike ————— 13.90
fishmen67 --------- 13.80
sr71mopar————- 13.75
273 ----------------- 13.70
Garrett Ellison——- 13.58
331MP ------------- 13.40
RustyRatRod ------ 13.016
The RB engines tend to perform very well with a single plane as a function of runner length. I think it would be close with the open plenum, but the RPM probably has a lot more even cylinder to cylinder flow. But it would be fun to see back to back runs with it and the 4.30 gears. But Man, spring was already taking too long to get here… no doubt about, this one’s going to be worth the wait!
:popcorn:
:popcorn:
I brushed the snow off the truck yesterday. Woke up this morning and it was snowing and recovered it.. :eek:
Thanks for real numbers. Can I ask are you hooking up a y-pipe and 2" single exhaust with a cat and a factory style muffler to the manifolds for those numbers? Do you think 40 hp is a reasonable expectation for a '77 440 going from the '77 manifolds/single exhaust/muffler to Headers/2.5" duals with FX mufflers?
Those numbers are from multiple test compairing cast iron manifolds with 48"×2" pipe on the small cam and same manifolds with 36" × 2" pipe on the big cam motor (each was optimized for pipe length) to mid length header with 2.25" × 41" pipe small cam motor and same mid length header with 2"x 30" pipe. Again both optimized for length. Difference in diameter of pipe was a rule to try to help the small cam motor.
If you want to test the difference between exhaust systems bring your motor over and I'll dyno it for free.
My thought with the torker was when I build the 440, it will be the right intake. I wish I had an RPM, I would swap it at the strip and give you the before/after right there! One of the benefits of the 8 bolts and dry intake
Maybe someone on fabo has one they can loan for a test. If I had one I certainly would. Anyone have an intake they’d like to loan and see a test with?
I am not too far away. No RPM intake, but I have a tunnel ram if you want to try that.
That would be fun and that's generous of you... but I think we are close to 6 hours apart.
Here I thought first run off the trailer, oh well.
Dan
I don't think I've ever mentioned "off the trailer". Others have and I've always said best run of the day. Trying to get the 440 a fair opportunity to show us whatever it is it may have... LOL
I'll go 14.53
We got you down as a 14.53!
69conv—————— 14.80
mopowers————- 14.53
Put me down for 14.32
Got you down! Look at that list!
69conv—————— 14.80
mopowers————- 14.53
MOPARMAGA———- 14.32
69conv—————— 14.80
mopowers————- 14.53
MOPARMAGA———- 14.32
Quite the list, impressive amount of pages in the thread too .
