Brake Booster big block
hardyrw1
Bothell
I was at the Mopar car show in Everrett, WA last weekend and there was a guy running a new gen hemi in it and he had a power brake booster that appeared to be on a braket and sat forward and up away from the fire wall a bit. I'm dropping a 400 in my dart and thought a set up like this would be great for power brakes. Any body have something similar they are running with their big block? Any picks of power brakes on a big block would be great!
Power brakes are not needed with the correct master cylinder. 87 dodge ram manual disc Master as seen below. Stops with very little effort at very very high speeds. No vacuum problems do to larger cam either as you would have with power brakes.
I also run a manual steering box with bearings instead of bushings on the sector shaft. Steers with one hand with a tuff wheel and has no bind on throttle pulse during counter steer like power does
Also mounted alternator on the left with power steering brackets so I have no wires on motor.
What is the bore diameter on that M/C ? And where did you get the steering box with bearings installed? Thanks.
I'd be interested in finding out more about the steering box as well. Thanks for the help
I would like more info on the MC as well. Ram van? Ram 50? Ram truck? Searching Rockauto for a non-power MC for these models, it does not list one.
Lotta engines I build don't have enuff vacuum for power brakes.
I regularly toss the booster and install a small bore manual Master, 15/16.
It's direct bolt on. No messing around changing stuff.
Raybestos also has one. Can be hard to get
Good luck
Just reporting in as of Dec-2025 the MC36406 from Rockauto does indeed still have a recess for a manual rod. It's not much of one, .020-.030 by eyeball but it's there.
