Anything new or rebuilt would be expensive, unless you luck out like me. I found a booster for my 65 Newport at $70 clearance price on rockauto. Best deal new is a $170 A-body setup on ebay that uses a GM booster (several posts here). You can find much cheaper used, but once the rubber in the diaphragm fails you pay $$$ to rebuild. I hope you know you need more that just a booster, you need stand-off brackets w/ lever and the pedal rod, as shown above. Perhaps use the opportunity to change to a safer dual reservoir setup, like I did on my 3 Mopars. On my 65 Dart, I used A-body stand-off brackets (from 74 Dart), but a booster/MC from a 95-99 Breeze. Those will be easy to replace. The same booster is on Intrepids, and junkyards are full of cloud cars and LH's.
