Its been a long time since I worked on an early A, but if you are talking about the little compression springs inside the wheel cylinders,then they are sorta married to the master cylinder type. If you have the OEM M/C then yes reinstall the original springs, so long as they properly fit the new cups and seats, and are in fine shape.Otherwise the kit manufacturer has matched the cups seats and springs together.Those springs have 3 jobs; 1) to keep the cups out against the metal plugs so that the cups dont go sideways, and 2) to keep the edges against the cylinder walls, and 3) to not wear out or damage the cups while doing jobs 1 and 2. Not rocket science, but important none the less.Pics would be nice.
-Now if you are talking about the brake shoe retaining-springs, that retain the shoes to the backing plates; New story. Those springs are matched to the little retaining rods, and to the spring seat/retainer-cup,and to the shoes. They are a set. If the shoe manufacturer supplied them;use them.They may be a "change-up". Just make sure the shoes arent flopping around after the install is complete.
-One more thing, if you are a first timer; Before you take anything apart, match the new shoes to whats on the car to be sure they are dimensionally the same, and all the holes are in the same places. And finally, do one side at a time, so that if you get lost you have a pattern on the other side.
-If you have self adjusters its imperative not to mix the adjusters up;side for side and north/south. One is left-hand thread,and the other is RH. And almost all 9in parts are different from 10 inchers. And the shoes have to be correctly oriented; long linings to the front.And again, if you have self-adjusters the return springs are different. Dont forget to service the adjusters. I put anti-seize on the threads.I also polish out the 6 places where the shoes rub on the backing plates; 3 front and 3 rear.This smoothes their engagement and if you put a tiny bit of anti-seize there it may quieten them.
-And if you dont know when the last time was that the wheel cylinders were done, I highly recommend that you do them now before the new linings go on. There is a high degree of probability that they will leak in their new working location; ruining your brandy new shoes. If honing is required ,you can do that right on the car, just block the compensating port in the M/C by locking the brake pedal down about an inch. That will prevent all the brake-fluid from running out.Of course new cups etc. are recommended.Bleeding is not the scary job everyone thinks it is. Take your time. It will be ok.
