brake light wiring help please
63VALIANT*KISS
Eureka,Ca Humboldt
if i could pick a couple peoples brain here for this tough question.so first time i went to the shop and they "fixed" my brak lights they went out i took it back and they said i needed a new turn signal switch but he bent the copper down cause it wasnt touching right so the light didnt come on. anyways now there both not working i want to know exactly where the wires end from the tail lights to the dash where do they go i need to check connections with my geez it slipped my mind its my screwdriver with a ground and light but yea please if someone can tell me where to look the turn signal still works just the brake lights.
under the dash,lil switch mounted to the steering column brake pedal support,has a pink and a white wire leading to the switch,pink is hot and white leads to the turn signal switch then to the brake lights,the switch has a bolt that holds it to the column brace and is the adjustment
got it ! burnt fuse couldnt see it last night in the dark i also had to play with the directional indacator switch but yea and thanks for reminding me test light! thanks for all the great help guys any one have a switch for cheap that works.?
take it apart and clean it be careful of the lil plastic blocks that slide back and forth noting wich way they are installed befor you remove them,usually a new turn signal cam is all that is needed....vansautollc on ebay sells em and gas tanks and sending units,
