chad72duster
OK I went out to drop the rear out from under my duster. everything is cool up untill the point when i go to cut the rubber brake line loose from the steel line so i can drop it. The fitting is on somet kinda tight and i have just about rounded of the flare nut fitting any suggestions on getting this off? If i end up screwing up the fitting can i salvage the brake line by re flaring the line?? If i can reflare it who would have a replacement line?? What a pain in the Axx.
