Brake lines
Colorado
Hello,
I'm hoping someone knows who sells brake lines, not in kits. I've replaced the old master cylinder with a dual reservoir. Looking for lines from the master cylinder to the distribution block and from the block to the driver's side rubber line.
Any help is greatly appreciated.
I bent my own from the MC. I was pretty happy with the result. Coiling the lines took a bit of practice but I got them to run as I wanted with the booster moving the MC forward.
Good luck there.
just go to your auto store and buy straight sections the correct length and bend them yourself.
I think i used about a 2" pipe for coil and radius sections.
I bend and double flare (must double flare, DOT requirement) all my lines myself. I like the copper nickle lines as they bend easily and NEVER work harden. They also flare like butter. I get it in coils.
You can get a brake line straightener for around $85 and up. There is a free method I use to straighten which employs tension. I do it differently than this video but you will get the idea.
I am on my second set of stainless steel Inline Tubes (IT) brake lines on my MC. The connection at the MC for the rear brakes will not seat - it weeps.
I attached the lines according to IT’s instructions, but no help. That’s when I broke down and bought another set - same damn problem.
Then this past weekend I watched “Gearz,” and he was making brake lines and he commented that you should use nicopp or steel, but not stainless steel. The reason? Stainless steel cannot be double flared- only single flared, and that tends to crack, or not seat, and will probably leak.
Tomorrow I will try to make a nicopp line, double flare it and see if that leaks.
