Jimbo_74_Duster
Active Member
Hey All,
(Working on a 1974 Plymouth Duster 360, front end rebuild/drum to disc manual brake conversion)
I cannot get my brake pedal to stiffen up and I've bled the brakes 6 times now. What happens, is that it starts to stiffen up until I move to the front right brake. Once I bleed that, the stiffness in the brake pedal becomes almost non existent and it's all loose again. Here is the kit I installed. Here is the prop valve from Doctor Diff and here is the master cylinder.
(I am bleeding them by the book with someone on the pedal, correct fluid and in the correct order; rear right first etc. I triple checked my installation job of the proportioning valve and the brake line mapping and cross checked it with my hard copy shop manual. There is also ABSOLUTELY no fluid leaks on the floor. I'm guessing people are going to say the kit I bought is not a reliable one and or the master cylinder.
Thanks for the input
