Brazilian Dodge Dart 76 (similar to 69 usa)
very kool.. be careful running on just the exhaust mainfolds and no down pipes and warp the valves,,,cold air hitting the valves after being so hot,,
This buildup is insane, and i want to tell you in this picture of the installed front trany seal you did it wrong buddy this seal is installed backwards, just trying to save you some headeches my friend!
attachment.php
Hi thanks for your message.. unfortunatly I notice that I installed it backwards toooo late.. Had a lot of work to remove gearbox...
When I installed it I was too busy and confused.. later I told to a friend that I was confused and asked him to see this photo... lots of things do in a small amount of time... **** happens! =P~=P~=P~=P~=P~
attachment.php
Hi, I installed a piece of pipe.. about 2 meters 2x1 ... not a good choice, but good enought for the moment.
We´re testing for small amounts of time because water pump and exhaust.. but here is tooooo hot.. about 30 celsius (86F).
I also got an old fuel pump to test engine and carb .. hope to get iddle working now.
Hi guys
I installed front fenders to move the dart to another city..
I think car is pretty good.. looks nice..
this side just have some minor pieces do work.. all body "lines" are really nice
Both columns have problem.. I will have to weld it
I think it is a Ford air cleaner case .. didn't work as I wanted.
I also cleaned old seat.. just to use as a collection item
Finnaly.. I really look nice! Hollywood is wasting a really nice man
attachment.php
nice catch,, any pics of how it should look?? cant rememebr how it looks even tho ive done my own,,
Hi
"DI" side must point to the oil side.. As we want to seal the gearbox, "DI" must point to the gearbox and "DE" to the engine.
As you can see, I installed it just the oposite. I was having a bad day and didn't notice it.
you have done such a fantastic job on this project with your limited resources. Something I would of never considered doing. Congrats to you I hope you can drive it soon because you deserve it Alex!
thanks for your message varlo
I think I will need at least 6 months to ride it the right way... but I do have a big temptation... take a look what I did today at lunch time
a friend gave to me an used fuel pump. Now I will test carb and engine with correct pressure in the fuel line. Hope to get iddle working nice now
I told that I had to remove gearbox to fix the wrong installed gasket (oil seal).
I used a small jacket and some friend help
wtf!!!
Alex, the fuel pump turned to be an excellent part!!it was so dirty, that it was almost sent to trash...lol
great job cleaning it!!
looks like new!!
happy new year, everyone!!!!!!
Happy newwwwwwwwwww yearrrrrrrrrr
gas pump works fine.. I isntalled it today. I had to bend oil stick tube. But it was easy and engine really looks pretty.
Unfortunatly, my carb still haven't iddle working. I think I will have to clean the carb plate again..
happy new year with lots of mopar
wtf!!!
looks like new!!
front bumper and hood.. I'm having some problems with hood hinges
and rear seats.. ready to go to new city
Great work, Alex !!
Keep up with this fantastic job, my friend, and we hope to have your car complete and running strong by this year !!
A big Mopar hug from the Dodge guys of the south of Brazil !!!
Mário Buzian - Ivoti/RS
forgett the car lets see some more wife :) cars looking great to man hahahaha
what kind of problems with the hood hinges are you having?
Hi dusterbd13.. the hood hing insn't folding. I think it opened more than it should and when I push the hood to close it, the hinges tend to fold the wrong way.
I will put them (both hinges) in my workbench and check if their backstop have to be repaired.
More wife? no no no :bootysha::bootysha::bootysha::bootysha::bootysha:
I will make her a web site to display her photos as model
Alex...you will want to weld a washer on the post that the hinges slide over....I guess it's the same as 67-69 cuda's?
The hinge will press off the clip that holds it on now if allowed to flex side to side that much and the hood will fall on the cowl ruining your bodywork/paint. sounds like th ebushings on the hinge are shot and some weldomatic work is required...
Ask me how I know.....ooops.
Mop
thats exactly what you describe. when I tried to close the hood, hings almost flex to side and almost run out of the car..
I removed the lower hinge clips to close hood.. when I need to open it, I put a big wood stick to keep it opened (an old broom)
I think you know it with a very very bad experience :angry7:
I'm not sure if they are the same as 67-69 cuda´s; I found a picture here in Fabo
as I know, Brazilian darts are based on 68-69 American darts
Mop
My hinges would not fold when I put them on the car. I had to take them back off and found that they were rusted. I put them in my vice and bead them with a dead blow hammer until they would move.
