T56MaxTorq
Hey all, have a LA360 in a rebuild and have a comp roller cam that needs a bronze gear for the oil pump drive. Deciding what driveshaft to go with is giving me a headache. The motor and cam has been ran about 3000 miles before the heads burned enough oil and well..I'm rebuilding everything a second time :banghead: The old bronze gear came as just a gear that I press onto the stock driveshaft. Well upon inspection the gear is worn way too much for comfort. It seems the shaft bottomed out and was slightly pressing the bronze upward onto the cam gear, causing irregular wear. So with a few choices in bronze gears with hardened shafts (milodon, MP, Comp cams, etc) Are they all interchangeable? I did a quick search on fabo and are there really 3 different sizes? I think I have a stock melling replacement oil pump but it may be high volume. Thank you.
