Bucket seat swap question.
69GT
Metro Detroit
I want to put bucket seats in my 70 Dart which is an original bench seat car. I looked underneath the car and there is no second set of holes for buckets so I took out the bench and rolled back the carpet expecting to at least see some dimples in the floor pan to indicate where they should be but there aren't any. I thought there would at least be some dimples as my 69 Dart, which is an original bucket seat car, has both sets of holes. Is this typical for a car that is originally a bench seat car?
Bucket seat cars got plates welded to the floor to reinforce the floor for the seat tracks on the inside near the tunnel.
They’re simple to make 6”x6” 1/8” plate with a hole in the center, even a moderator could make them.
True. I own a metal fabrication business.
Sometimes it's cheaper to buy small parts then pay an employee to make them..
My 67 Barracuda fastback bench car had dimples that I drilled out to fit buckets way back when. After I wore out the junkyard buckets, I went back to a bench seat for uniqueness. One warning about drilling the holes – one of them is very close to the rear brake line. Close enough that the fender washer I used had to tuck under the line. I didn't add any reinforcement plates, but that's because I was young, stupid and cheap.
