New super stock springs- moved inside frame rails, Frame rail connectors, 538 gears, 8¾ Chrysler rear-end with Moser Engineering axles, Tubbed, 5 point harness, Adjustable rear shocks: 90/10, 70/30, 60/40, 7 point roll cage, 7 gal. fuel cell, ½ copper gas line from tank to regulator, Fuel cool can, Hurst line lock
Mickey Thompson slicks: 31x13x15 (20 runs on tires), Rear mounted battery, 4 wheel disc brakes
Holley blue electric fuel pump, 2- Drive shaft loops, Weld wheels all around
Goodyear Front tires: 6x15L, 6 pack hood scoop, 4 core brass top radiator
Exterior mounted fuel and oil pressure gauges, Custom drive shaft, Autogauge 8000 rpm tack
Fiberglass front bumper, working exterior light, Slicks pinned to wheels
Cartoon duster sand blasted on door glass, MSD 6AL ign. sys., B&M shifter
Duster scene etched in rear glass
Transmission
727A, Cheetah reverse pattern valve body
8 TCI 5 grand torque converter, Transmission blanket
Engine
Small Block 360 (punch 30 over), 12.5 : 1 Compression
Cast X-heads (2.02/1.60), Comp Cam: 585/312 mechanical
Holley Strip Dominator intake , Holley 830 Double Pump Carb.
Car ran 11.30s with present setup
THIS car would be PERFECT!!!!! :headbang: ,i wonder if its STILL forsale??
