Build sheets, where are they?
67 baccaruda
Member
Colorado
I was given a build sheet with my car when I picked it up today. Since it came out of the lower back seat cushion I assumed it was correct for the car. WRONG!!! :cussing:
It's off by about 800 numbers in the sequence.
Where else did they hide these things in a '67?
I know where to look in a '70, but still learning about '67's.
BTW, the one I have is BH29D72217742, and it was a Buffed Silver car.
Anyone happen to have this car and needs it?
I don't know if it is different for the 67's. I would look under the carpet, up behind the glove box and under the seat cushions.
I think the mopar expert Galien Govier (spelling?) has a means of trying to re-unite owners with their build sheets. You give him the number and your contact info and he will give your contact info out if the owner contacts him.
Rod
Good Thread i know it can vary but what about a 66 where would it be?
it wasnt under the front bench.. nor the rear. i have had both out and searched. i just didnt search in the backrest of the fron bench.. any suggestions?
Odly enough the 74 pickup i got my motor from.. had its build sheet in the tranny cross member?!?! that threw me off a little.
-Cerwin
My 68 GTS convertible had one on the top of the glove box liner and one inserted beneath the back seat upper springs (visible from the trunk). I removed them both over twenty years ago and have them safely stored.
