dodgefreak73
I built a new coffee table:coffee2: for the living room on the weekend! I scored a damaged 20 inch Ram wheel from work a couple months ago as well as a front wheel bearing and the wheel nuts. The table rotates on the wheel bearing as well as the base that it was mounted to, it is also adjustable for height as well depending on how high it needs to be to work with the other furniture. The base is an office chair base modified slightly and the wheel bearing is welded to the plate the the seat cushion was on. In the background of a couple of the pics is the lamp that I built a few months ago using a camshaft and cam gear. I enjoy doing this kind of stuff whenever I can.
