Has anyone put a cable type gas pedal assy. in a 62 Lancer? If so what did you use? I have a setup from a 72 Dart which doesn't leave the pedal in the right place.
Thanks for the pic! It looks like mine needs to move to the right a little but the tunnel is right there. So I think I will have to bend the arm to get it right and bend it up to get more throttle.I just put a pedal from a '69 Dart into my '65 Valiant 318 4 speed. I moved the pedal over to the left about 2" because the original position had the pedal hitting the 4 speed hump. Pretty simple, I had to drill a new 1" hole in the firewall for the cable to go through, and 2 holes for the mounting bolts. I bent the rod the pedal attaches to slightly for more throttle.
You can just see it there behind the brake pedal.View attachment 1715410654
