cal trac - inboard springs
littleman66
so i was out measuring everything for inboarding my springs. and while i was at it i was going to make the shackles for the cal-tracs.
BUT after i had everyhing figured out, i noticed i can't put cal-tracs if i have inboarded springs!
is there anyway i can still make them work?
what else can i do that does the same as cal-tracs, other then the 3 link system(i dont like the no ground clearence idea)
The cal-tracs will work with the inboard springs.
I've heard Calvert worked out something for this.
Maybe notching the boxes will work. I know I saw pictures somewhere withthe springs inboard and cal-tracs.
o wow.....i did not relieze they bolted to the front hanger.
how could of i missed something like that. thanks though!
by the way, i can only find one write up on inboarding the springs on a dart. are there others out there?
They don't actually bolt to the front hangers.
The spring bolt goes thru them.
Bigblockdart.com has a tech artical on moving springs.
Quick and ugly notch...
Hey 383 posts!!!!
That's one of the other pics I remembered,
Hey Walt, Does this mean You won't post any more, Cause it's your engine size?
dam thats ugly :silent: o well ill find a way to make her look good
no offence to your car, im sure you will eventully fix her :salut:
That's the new way to make mud flaps! :)
I think he has it fixed already, Look at his pic below his post.
OK, I guess I will keep posting. I may have to stop at 431... The new engine.
That picture is one of a series showing the wheel openings getting bigger for taller tires. It just happens to show the notch in the spring box for the Caltracs.
http://bbdart.com/mycar/tightfit.jpg
http://bbdart.com/mycar/sawzall1.jpg
http://bbdart.com/mycar/sawzall2.jpg
http://bbdart.com/mycar/sawzall3.jpg
http://bbdart.com/mycar/sawzall4.jpg
http://bbdart.com/mycar/sawzall5.jpg
http://bbdart.com/mycar/sawzall6.jpg
http://bbdart.com/mycar/sawzall7.jpg
http://bbdart.com/mycar/notsotightfit.jpg
so i was going to make my cal-tracs today...and i thought i had it all under control by just copying this one http://www.hotrodsandhemis.com/Traction.html
but it says "To keep the forces equal the bottom hole of the bellcrank should be the same distance from the pivot point as the pressure point. In this example the measurement from the spring eye to the second spring was 12". We use half that measurement (6") to determine the length of our bellcrank. (See figure 6) Don't forget that you need 4 identical brackets."
so its saying i can't use the bellcrank example that is 6x6x6....???
if not does anyone know what the measurement is from the spring eye to the first spring?
i would go measure it but that means i need to go all across town, come back home and fax all the info to a friend....its getting late since i have a final exam to study for tonight.
Littleman, that is the same reference I used for mine - good info. Just remember use it as a guide, not a blueprint. The leverage/geometric "principles" are the important part. My cranks ended up measuring around 5" hole-to-hole, as I recall. Where the spring pressure point contacts is important but not a precsion measurement. As long as they hit close to the end of the 2nd leaf they'll be fine. You probably have a good range of around an inch more or less. Here's a link to my Duster page with some pics. Maybe give you some ideas:
http://66.17.171.114/PhotoAlbum/Cars/Duster.htm
thanks alot. so would it be a good idea to make the measurments AFTER i reark my springs? beause i was going to do that after
