Calipers wont release
Brakes for your Classic Mopar
  1. 74demon
    74demon Well-Known Member
    232
    13
    Nov 10, 2008
    baltimore,md
    Local Time:
    6:28 PM
    Im sure this is a repeat issue but...here the deal
    70 swinger originally drum car now has 74 front brake wildwood rear brakes (got them dirt cheap new in box unopened will get matching front over winter) new rubber lines to calipers and rear axle new master cylinder new calipers pads rotors the fronts wont release unless i crack the line bolts at calipers ( bleeder made no difference) rears haven't had chance to look at that yet but im sure im not first guy with this issue of someone could point me in right direction i would appreciate it
  2. MoparMike1974
    MoparMike1974 Well-Known Member
    1,711
    1026
    Jun 16, 2017
    Maryland
    Local Time:
    6:28 PM
    I would swap out the rubber hoses and see if that cures it. I have seen the rubber swell the line closed. I know your hoses are new but we all know the great quality of parts these days.
    • Like Like x 1
    • 74demon
      232
      13
      Nov 10, 2008
      baltimore,md
      Local Time:
      6:28 PM
      For got to mention the proportion valve is not new but never gave me a indication of any issues prior to this
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      56,343
      25259
      Jun 7, 2010
      Georgia
      Local Time:
      6:28 PM
      Anything done to the master cylinder?
    • 74demon
      232
      13
      Nov 10, 2008
      baltimore,md
      Local Time:
      6:28 PM
      Nope just a standard replacement part old one was leaking
    • plumkrazee70
      plumkrazee70 FABO Gold Member FABO Gold Member
      2,234
      546
      May 5, 2013
      Medford, Oregon
      Local Time:
      5:28 PM
      Is it possible that you got a drum/drum master cylinder, which has residual valves in the ports? Im, pretty sure that was designed to keep pressure on the brake drum shoes.
    • RustyRatRod
      56,343
      25259
      Jun 7, 2010
      Georgia
      Local Time:
      6:28 PM
      Be CLEAR dammit. So then was it replaced when all this other was done?
    • 74demon
      232
      13
      Nov 10, 2008
      baltimore,md
      Local Time:
      6:28 PM
      Yes it is possible i got one for drum car....once i got all my brake stuff to do the swap is when was replaced none of this has seen a street
    • plumkrazee70
      2,234
      546
      May 5, 2013
      Medford, Oregon
      Local Time:
      5:28 PM
      Check the part no. That would be my guess though for calipers not releasing. Or possibly the slide bolts not greased up, but that seems like a reach.
      Check out Dr. Diff, he can set you up with the correct master.
      • Like Like x 1
      • RustyRatRod
        56,343
        25259
        Jun 7, 2010
        Georgia
        Local Time:
        6:28 PM
        Unbolt the master cylinder and pull it forward. See if the calipers release. If they do, adjust the rod going into the booster shorter. Sometimes master cylinders are machined to different tolerances.
        • Agree Agree x 2
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          40,491
          8133
          Oct 14, 2010
          Idaho
          Local Time:
          3:28 PM
          X2........or crack the line fitting with a rag(s) under and see if pressure releases
        • RedFish
          RedFish Well-Known Member
          23,586
          2340
          Sep 5, 2007
          Local Time:
          6:28 PM
          The brake lamp switch adjustment can hold the brakes on.
          It can also kill a battery in the opposite condition, so that adjustment should be checked with every master cylinder service.
        • G50
          G50 Tetanus
          59
          35
          Sep 10, 2016
          Texas
          Local Time:
          5:28 PM
          I was just scrolling along in here, searching for ideas. My front calipers were licking down and not releasing (all 4 brakes are all new). I popped the MC lose from the booster and BAM! everything's fine. bolted it back up and lock up :-( Come to find out (stupid me), brake pedal was returning enough to turn off the brake light switch but still engaging the MC. I hooked up a return spring and all problems fixed. I don't even know if my Dart Swinger was supposed to have a return spring. Anyone?
          G50
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          9,769
          3985
          Nov 28, 2008
          NorCal
          Local Time:
          3:28 PM
          There definitely shouldn’t be a return spring on the brake pedal, something’s screwed up. If the brake pedal rod is too long it can do that. Or an internal issue with the master cylinder or the booster. But the brake pedal shouldn’t need any kind of a spring on it, that’s bad news.
        • RedFish
          23,586
          2340
          Sep 5, 2007
          Local Time:
          6:28 PM
          Nope. No brake pedal return spring.
        • G50
          G50 Tetanus
          59
          35
          Sep 10, 2016
          Texas
          Local Time:
          5:28 PM
          OK So that explains why there was no return spring then. Now what? There's a contact bolt (if you will) between the MC and the BB. There's plenty of room to screw that in and lock it down again. Could it just be from run too far out from the factory (China?)?
          G50
        • RedFish
          23,586
          2340
          Sep 5, 2007
          Local Time:
          6:28 PM
          maybe. Factory service manual will detail how that is supposed to be set up.
