mopar56
So I am attempting to wire up the signals, flasher, and horn in my 56 Dodge truck project, I am using a donor steering column that came from what I suspect to be a mid seventies to eighties Chrysler, it is unique in that it has tilt AND telescopic steering, ( Chrysler borrowed this design from GM ), the pigtails were cut off prior to me getting it but I have listed the colors below, I have looked over many of the wiring diagrams in the "mymopar" site but the colors still don't seem to match up so I thought if I am thinking this correctly there should be a power source into the steering column/actuating plate and depending on which way you switch the lever for the signals power should then feed out another different color wire, at this time as I am still wiring this up I do not have any power supply hooked up or even a place to put one, ( no battery, tray, starter relay, wires etc. ) so I thought I should be able to do this with an ohm meter right?, so unless any of the wires in the harness are ground then they should not have continuity between each other until you move the signal lever, but this is not the case in fact almost all wires I checked HAVE continuity between each other with the signal lever in the neutral position, this makes no sense? the switch seems fine, I have no reason to suspect it defective in fact I have the steering wheel off so I can see its operation and condition, if my theory of one of these wire being a feed wire is correct and I knew which color it was this would be helpful as moving between each wire and trying to figure this out is a little like trying to figure out a correct lotto number. The harness that I suspect that I should be tracing has green, purple, blue, brown, four blacks, one with a white tracer and one with a blue tracer, there is also a separate yellow wire beside it, maybe it was peeled away from the the main harness up in the column and just seems separate?, lastly there is a small four wire harness which has been cut off close to the column shroud, I am pretty sure this is for the cruise control it has smaller gauge wires and moves with the cruise control/signal lever, the colors are blue,black, white, and yellow, I do not plan on using these as I am not using cruise control. Inside the top of the column ( steering wheel off ) I can see a grey wire and possibly grey with black tracer and a pink wire, I think these are part of the actuating plate that connect to this harness and why they don't make them match the others I have no idea? I am pretty sure the pink wire is for the four way flasher but don't know which color in the harness it should connect to, So any one here have any ideas?, unfortunately this little speed bump is holding up progress on the entire build as I cant get my head around this, sorry for the long post but thought I should put as much info as possible here, thanks in advance.
