I'll try this here since moparts' technical forums bite balls.
I'm about to order my camshaft for the 5.9L Magnum with LA timing set/fuel pump, and I have come to a crossroads. I need your advice on which path to take.
Right now, I am cylinder-headless. I have the original iron Magnum heads, but they each have a couple of, from what I can tell shallow, cracks between the valve seats. This precludes me from just slapping on the cylinder heads and running them, as some work should(I think?) be done to make them work optimally.
So now I need a push in the right direction. If I go with my first cam choice (int: lobe lift: .361/dur @ 50: 230.00; exh: lobe lift: .358/dur @ 50: 236.00), I will have a large valve lift, but I will not be able to use the stock Magnum heads. They just can't handle that lift. However, if I go with this cam, I also must purchase new heads, and could that take almost half a year.
However, if I go with the second cam choice (int/exh lobe lift: .305/dur @ 50: 214.00), then I can run stock milled heads for the time being, while saving for Edelbrock heads. However, this will obviously yield much shorter valve lift, robbing potential power.
And there's a third option, I guess. I can buy the high-lift camshaft, but leave it in the box for now. I can purchase a fuel pump eccentric for my stock Magnum cam (LA front cover), which looks fine, and run it with the stock Magnum heads for now while I save for Edelbrock heads.
Which would you choose? I would love to get this motor running by January, and would stand a real chance of that without having to buy new heads. But buying new heads gives me lots of other perks, like more power and better heat dissipation. I am pretty set on one of these three options and I'm definitely set on either of the cams, I just don't know which one. Your help's greatly appreciated!
