Cam Guru's help w/ID
Small Block Mopar Engine
  1. 'Cause
    'Cause need lots a parts
    70
    35
    Mar 3, 2017
    Arizona
    Local Time:
    8:43 PM
    I have a 340, 1969, w/X heads
    It is stock bore, No ridge at top of bore, crank never turned
    Supposedly about 68K miles when pulled out and been sitting. Yes it is clean, not a rusty POS, just some varnish like dried oil in it. It did turn over at the crank.
    I'm taking it apart and to have some work done on it to freshen it up by "Dennis Maurer" in Tempe AZ. Blank
    I pulled the cam and I'm trying to find just what it is;
    There are only two marks on it that I can find, both at the timing chain end of it on the shaft.
    There is a D2 on the shaft on one of the bearing journal and a HIO on the other side, the HIO appears to of been a tag that was on the casting when made. That is all I have, I'm not sure if this will help or if anyone can help ID it from this. Most likely not, but I thought I would try.
    Thanks,
    Ken
  2. Wyrmrider
    Wyrmrider Well-Known Member
    1,233
    455
    Sep 5, 2016
    los angeles
    Local Time:
    8:43 PM
    Stock timing chain and gears?
    then for sure a stock 340 cam
    you could measure the base circle and lobe height to verify but most likely 4 sure a stock 340
    keep the lifters in order and it could be reused by someone or could be used for a low duration low lift regrind
  3. pishta
    pishta I know I'm right....
    14,245
    3914
    Oct 13, 2004
    Tustin, CA
    Local Time:
    8:43 PM
    if there is a small 7 digit stamp on the gear end of the cam, its an OEM supplier number, cant use to look up what it is. Usually aftermarket grinds have alot of info stamped on that end.
  4. 'Cause
    70
    35
    Mar 3, 2017
    Arizona
    Local Time:
    8:43 PM
    I looked all over the thing, begining at the ends where most are marked. That is what I thought was odd. Little to NO info.
  5. Bighead440
    Bighead440 Well-Known Member
    160
    101
    Jun 18, 2017
    Milledgeville, Georgia
    Local Time:
    11:43 PM
    By undercutting that generous base circle, you could get some lift out of it! I once sent a 455 Buick Stage1 cam off to be reground (all Buicks have tiny lobes because of the cam bearings) and the grinder called me and said even the mild street grind I was wanting (same lobe center, more lift and duration @.050") would fit better on a stock non-Stage1 core. He gave me the core he used and returned my core, so go figure?
  6. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
    15,653
    4650
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    10:43 PM
    I guess you'll have to measure it......
