I've been told this is a new MP solid either 528 or 590. Do any of these numbers do anything or color code? Single bolt BB
I will tomorrowDon't know about those numbers, but put a caliper on those lobes?
There are many references as to a colored stripe on a purple shaft cam for ID purposes. Unfortunately, I have been unable to find an ID chart. Best to give MP a call apparently for the color cross reference info.That is not a MP cam; all the MP cams I've ever seen are Purple, that's why they are called Purple shaft cams, the paint marks on the cam are meaningless; if your measurements are accurate, at .440 lift with a 1.5 rocker, it; the cam; is not eather a .528 or .590 lift MP solid lifter cam; more like a no-name stock replacement; though I will hazard a guess that the "circle M" MAY, MAY, be a stamp by Melling Tool who MAY have ground it.
