MikeD
I've just pulled the timing set off my 360 and there's no cam number at the front, all the BB Cams i've used had the number stamped on the end.
Mick
Mick
That's your problem right there, your engine is either done, never was, or the cam is 7 sizes too big, bleeding pressure.I 've done a comp test and lowest is 110 dry, 120 wet, highest is 145 dry, 150 wet, max vac is around 8", the power brakes are poor due to the low vac, car is high geared, stock converter, edelbrock dual plane, edelbrock carb, 1-5/8 headers. I was thinking more than 4 degrees, what's your opinion ? I thought the 73 360 was around 8.5.1 ?
Mick
You have one hole at 145/150, that hole probably is ok, at least ring wiseI 've done a comp test and lowest is 110 dry, 120 wet, highest is 145 dry, 150 wet, max vac is around 8", the power brakes are poor due to the low vac, car is high geared, stock converter, edelbrock dual plane, edelbrock carb, 1-5/8 headers. I was thinking more than 4 degrees, what's your opinion ? I thought the 73 360 was around 8.5.1 ?
Mick
Coupled with the boat-anchor hiway gears and stock TC, that poor girl is screaming in pain.
Yeah I know, I sound like an azz. But the truth is staring back at you. Measure the cam, don't waste your time re-timing it. Then do a leakdown test and find out where the pressure is going.
And Rusty says put it in at 100Mike D, the 383 with 509 how much did you advance cam? Crackedback recommends 6 to 8 degrees @ the crank. Or 3 to 4 @ the cam.
Yep, even 4 degrees advance is quite noticeable for off-idle and mid range performance. Helps if you are cruising around on a low compression engine.Fired the car up, it was idling a lot higher, reset it, took it for a run, it definitely pulls stronger and it idles really smooth now, i think the stock converter and highway gears are still holding the car back but i'm glad i advanced it, it hasn't transformed the car but it's definitely improved it some.
