Sorry for the edit:
What did that 10.20 car weigh? What was it powered by? What was the gearing?
"Almost 200" horsepower, with the car as it sits now, IMO, will not run low 10s. The car I mentioned previously, with another 175hp NOS plate, runs 10.50s. All day, in Las Vegas heat. To go faster, he ended up buying a B wedge powered race car that runs high 9s. It was cheaper than doing what his car would need to run much faster. There are significant differences in "street" and "race" cars. Street cars have to make more power, over a broader curve, and push more weight to make the same numbers. What you have is a crate engine short with some abuse, and a set of factory replacement design heads. I think while you could get close to 600hp out of the heads, the rest of the engine will need to be brought up to race specs: forged crank, better pistons, a proper hone, then heads that can flow an honest 320-330cfm, the intake and headers to match, new convertor, and IMO it will need more gear if it's not lightened. Call me a pessemist but I don't see it happening without a lot more than a CNC port and camshaft. Not low 10s. Not with what you have. The RPMs are good for around 600hp in max ported form. Doesnt matter what cubic inch they're on. They can't move enough air at any rpm to make much more. If you plan to use forced induction, again, I think it's not where you want to start from. If you want 10.20s from that car, in basically that shape, I'd look to build a "blank sheet" 4" arm engine, Indy 360-1s, up the gears to 4.56s, and build for that ET.
