I'm in the process of tuning a fresh 360. At idle in gear with the engine warm I am only pulling about 6" of vacuum at the intake. Does that sound about right? I knew that my vacuum would be pretty low the the amount of overlap in this cam. I have order a new power valve #3 and secondary spring set, because I'm sure that my secondaries aren't opening and my 6.5 power valve is ineffective with this low of vacuum.
Here are the specs
KB107's zero deck'd
Holley 750 vacuum secondaries
LD340
Cam is Howards Hyd Flat Tappet 277 283 230 236 .531 .547 108 104
Timing is set at 18 degrees inital
Idle is set at about 800 and idles decent for the cam.
Just curious if the vacuum sounds about right?
Here is the motor.
[ame="https://www.youtube.com/watch?v=RIZW4mxXCBs"]First fire up of fresh Mopar 360 - YouTube[/ame]
Here are the specs
KB107's zero deck'd
LD340
Here is the motor.
