Camshaft id please...
360PLUS
so cal
I Have 2 old school camshafts that id like to get specs on if possible
One is a Norris 356 DMS with a 7 on the left and a D on the right
Other is a Crane on the snout is SS-320-NC and rear 975 uc
can any one give specs and if solid lifter or hyd.
thanks in advance
That Crane SS 320 is going to be a BIG solid flat tappet, unless it's been reground. Probably on the order of 320/330 advertised duration. I had an old SS 310 in a Chevy 396 decades ago. It was 310/320 .600/610 ground on a 108 for comparison. But remember, the big Chevy had 1.73 ratio rockers, so the Mopar small block version will have less lift, but I bet I'm spot on on the duration.
It would not be a BIG solid flat tappet.
It's a 1 bolt cam . it specified as hydraulic special 236 244 @.050. Duration
Lift is .486 & .504 with a 1.5 rocker .
This is why the at .050 numbers are the standard because anyone could be fooled by advertised duration numbers which are useless.
My 264-268 @ .050 cam is barely cracking 300 on advertised.
And this one is 236 @.050 with 320 as advertised lol
thanks in advance
FYI​
Identify Crane Cam SS-320-NC​
I'm not sure if an H would be stamped on your cam to denote Hydraulic
All small block cams are one bolt. The old SS series used advertised duration stamped on the cam. Then later, they changed it to the CC series. I don't know what it was after that. The SS grinds were DECADES ago in the 1970s.
Is there a difference sateen the SSH & SS cam?
OP said & shown a SS stamp on the cam.
I guess I forgot about small blocks being 1 bolt only...which I might add is dumb to me
Sweeeeeeeeeeeeet!!!!!
Hell of a lash though!
The MoPar PurpleShaft solids are .028/.032" pretty much across the board, I always set mine at .024/.026" HOT and had no problems. Much less noise, and I ran them with 1.6 rockers as well. Play around with it, but unless you are lacking bottom end, tighter will be better up to a point.
Chevy was notorious for using lash you could drive a bus through.
