4spdragtop
OK, I'm a little stumped on this. Cam is degreed, adjustable rockers installed, thanks @CFD244 Troy for spacers but also for pushrod info lol. Lash is set .022. Solid flat tappet. When priming for oil with engine on stand, I have oil flow up to rockers, but not at the crank timing degrees that I have read.
From what I've read oil should flow at 90* BEFORE TDC compression #1 cyl for Pass side and 20* AFTER TDC EXHAUST #1 for drivers side.
If I'm doing this correct I am getting good flow, BUT
Pass side is 118* BTDC Compression
Drivers is 320* ATDC Compression, which is same as 40* BEFORE TDC on "EXHAUST" stroke correct?
Good oil flow, but timing events are different? Cam is old comp cams 20-247-4 SFT.
Any reason for concern?
69 and earlier balancer and tc. Engine is 70 340. Verified #1 TDC compression.
I can TRY to translate my method if need be lol.
Thanks
Thanks
