1. F21
    F21 Well-Known Member
    131
    61
    Dec 5, 2019
    Michigan
    Local Time:
    9:44 AM
    Thinking of swapping out my 590 camshaft and getting something more in the 2800 to 6500 Rpm range maybe something with less duration and try not to lose a lot of the lift staying mechanical also getting rid of the Victor 340 and going for an air gap door plane
    My thoughts are this way I will be in the correct power band on the street what’s your thoughts
    This is a 340 30 over stock stroke can’t remember the compression ratio I believe mid to high 12 B1 cylinder heads ported by hand they do appear to be opened up pretty good though not sure of the flow numbers crane 1.5 rockers 750 Holley 727 reverse manual valve body just had the torque converter tightened up from 4500to 3300 391 gear 26 inch tire duster
  2. 273
    273 Well-Known Member
    3,943
    1680
    May 14, 2012
    Ontario
    Local Time:
    9:44 AM
    Maybe regrind the cam ? And or add Rhoads lifters or different cam with Rhoads ?
    • Like Like x 1
    • 66Valiant528
      66Valiant528 Well-Known Member
      473
      279
      Aug 20, 2019
      Medway Ma
      Local Time:
      9:44 AM
      If you've got all that cylinder head I don't know why you'd choke it down.
      • Agree Agree x 1
      • dusterbing the peace
        dusterbing the peace FABO pyrite member
        84
        95
        Nov 20, 2019
        Bandimere, CO
        Local Time:
        7:44 AM
        • Agree Agree x 1
        • K.O. SWINGER
          K.O. SWINGER Meeting in the alley since 1976
          2,806
          2744
          Nov 18, 2010
          oregon
          Local Time:
          8:44 AM
          I understand where you're going. But I will say your current setup sounds pretty nasty. I'm curious what's your current shift point RPM wise.
        • OldmanRick
          OldmanRick Well-Known Member
          7,177
          619
          May 11, 2012
          Ladson, Sc
          Local Time:
          9:44 AM
          If you have the coin, a solid roller grind can give you the lift you need with a streetable duration now that you've lowered your stall speed.
          If i find a shelf grind suitable i'll post it.
          • Agree Agree x 1
          • OldmanRick
            7,177
            619
            May 11, 2012
            Ladson, Sc
            Local Time:
            9:44 AM
            • Agree Agree x 1
            • F21
              131
              61
              Dec 5, 2019
              Michigan
              Local Time:
              9:44 AM
              I am shifting at 7000 RPMs and the car is still pulling running on race gas 50-50 mix with 93 The car just does not seem that fast on the street it is set up more for the track I figure getting a different cam in intake bringing the RPM range lower will be a faster streetcar
            • F21
              131
              61
              Dec 5, 2019
              Michigan
              Local Time:
              9:44 AM
              However I did just get the converter redone a newer 750 carb and advanced the cam 4° I’ve not driven it since
            • 66Valiant528
              473
              279
              Aug 20, 2019
              Medway Ma
              Local Time:
              9:44 AM
              Drive it with the cam timing change. Try it
            • rumblefish360
              rumblefish360 I have escaped the evil Empire State! FABO Gold Member
              43,702
              15853
              Jun 21, 2005
              Florida
              Local Time:
              9:44 AM
              I would call Hughes engines and ask what they have for available cams. If possible, coin wise, a switch up to a 1.6 rocker would keep the lift up high. On a street car, the lift isn’t so super important, though I totally get the want of using all the lift you can get with a well done head. It’s something I say to do a lot. It’s it the end of the world if you don’t and leave lift on the table.
              Also see if you can get a Cometic gasket to drop the compression ratio. Yes I know you’ll loose the quench. But that is also not a huge thing when backing it down for the street. It’s great if you have it or can get it but at your current ratio, you’ll need to loose at least one full point of compression to use pump 93. Even more so with a smaller cam trapping more air.
              IMO, you can still get an effective street engine out of this mill configuration.
            • F21
              131
              61
              Dec 5, 2019
              Michigan
              Local Time:
              9:44 AM
              I did think about going with a thicker head gasket but how much would that even drop my compression
              And then on another hand not sure how much I want to put into this I am debating switching over to a 392 next winter and maybe selling the 340 and the 727
            • rumblefish360
              43,702
              15853
              Jun 21, 2005
              Florida
              Local Time:
              9:44 AM
              How much the ratio drops from a thicker head gasket is your homework to do which a compression ratio calculator, like at the Wallace racing site is a huge help.
              Cometic gaskets are pricey but get the job done. There excellent gaskets made to your spec. .060 thick? .022 thick? .100 thick? Just tell them, they make them.
              If your on the fence about putting money into it due to the engine swap plan, I say skip it all and focus on the swap plan. Save money!
              • Like Like x 1
