Can CalTracs be used with 3 inch relo. kit?
pettybludart
Ontario,Canada
I,m wondering if anybody is using CalTracs after doing the 3 inch spring relocation on an Early-A body?I,m thinking about getting some for my 66 Dart,would like to hear if it can be done?Thanks.
This is all I could find, hope it helps somewhat.
When you order from Calvert tell him what you are doing and he'll set you up with the right stuff. I believe the kit is a bit different when used with the relocation boxes.
Good info and photos here. Go for it Scotty!
Cantilever for the inboard boxes.
The force rod is welded in, not a bolt like the std leaf mount set up.
I have a question about CalTracks too. They say they are available in 20" or 22" front segments. Whats the difference and what langth should you use?
a body need 20 inch front segments...your B/E body cars would use the 22 inch ...
just like leaf springs...A body use 20" front segments.
