Can someone help me check the oil. Please
pittsburghracer
Legandary Member
Legendary Member
Freeport, PA.
In order to check the oil level "properly" she needs to bend over a little more???????? Once you get the dipstick in "all the way" you'll know the correct oil level. Be sure to stick the dipstick in as far as possible in order to be satisfied with the results.:thumbsup::thumbsup::thumbsup:
USED TO B MY FAVORITE WAY ,----------
Proper way us to push all the way in, pull out, wipe it off Then full insertion again. Then remove and make sure it's moist to the line.
