Ok, I fixed the cold start issues, I have a new issue with acceleration bog.
This appeared after I rebuilt and installed a new, not re-manufactured carter BBS.
The car will fire up just fine at a nice fast idle, I let it warm up for a minute or two and I push on the pedal to put the carb to a nice mid-idle, I back out of my driveway, put it in drive, and put my foot on the gas.
I'm only gently accelerating, and the car stumbles, and almost stalls, sometimes it does stall. This happens until my engine fully warms up and then it goes away.
I'm going to replace my spark plugs since they are two years old. I had the NGK ZFR5N with the washers removed.
I also installed a new fuel pump with the ECS vacuum fitting for my 1970 198 slant. I do not have that hose hooked up, its plumbed.
The old fuel pump oddly enough had more travel in the fuel pump arm, this new one is a little tighter with less travel.
I have the float set dead on, and the choke operates well, wide open when hot, closed when cold.
My fuel tank gas cap is also the non-venting type, I have ECS on my 1970 Slant six, could this cause issues?
What do you think?
Thanks.
